which is more responsive to the continuous fast load fluctuations (0-250KW/sec) the gas turbine or the gas reciprocating engine with the same power rating (1500KVA)?and what is the effect of the fluctuation on both of them?
Is there a minimum load so the gas turbine can run?
Is there any standard talks about this subject?
Thank You
Thank You
