I need help in replacing a speed sensor installed on Waukesha gas engine 12V275GL by another type, as the installed one is not working in a smooth manner and stops the engine on "too many magnetic pulses alarm". the question is how to choose the correct magnetic pickup type for this application!
The installed magnetic pickup Model is: 640B01
Platinum 4-20 mA Output Velocity Sensor, manufactured by IMI sensors.
Note: this problem is happening in 3 identical Waukesha gas engines.
