this is my 2nd question posted here at control.com on the confusions i have in my plant.
this time it's about the seal steam.
As per the design, the turbine has 2 seal steam lines which is the supply steam and self steam.
The supply steam will be used during startup and once the machine is capable of self sealing, the supply steam valve should fully closed. However now although the machine is self sealing, the supply steam valve is still opened at 15.7% and it is dumped to the hotwell as the seal steam dump valve is opened at 84.9%.
This has certainly reduced the efficiency of the steam turbine as useful steam is wasted to the hotwell.
my question here is:
is the markv logic is correct on this matter?
if it is correct, then i assume that its a form of safety feature where in case the self steam level has dropped suddenly then the supply steam could help 2 maintain the pressure by closing the dump valve.
If it is not, then what shall i do to resolve this issue?
any1 having the same problem?
thx in adv
thx in adv
