G
Dear Friends;
I want equation/Formula to calculate delta P when there is a pressure/temp. change of process fluid for orifice plate flow measurement.
e.g., if for steam design press. 9 Kg/Cm2(g) Flow =5000 Kg/Hr Delta P:- 1000 mmWC.
Now if the Steam press. changes to 5 Kg/cm2(g) what will be the new delta P? (flow range remain the same.) Obviously there will be temp. change corresponding to press. (for steam.)
