N
Dear Everybody!
Now, I would like control system with 4 analog input and 4 analog output base on S7-300 PLC. That mean I want establish 4 single control loop by using S7 - 300 PLC and Analog In/Out module and programming for PLC execute control follow PID rule. After studied through document of PLC and functions It seem to be okay (I am not sure). I would like to ask you if follow is Okay?
Each single PID call via FB40/41 with different DB (data block). And using cyclic interrupt (system interrupt) to call sequently FB40.
For example in interrupt routine:
call FB40, DB1 // For control loop 1
call FB40, DB2 // For control loop 2
call FB40, DB3 // For control loop 3
call FB40, DB4 // For control loop 4
Of course, DBx is different. for each control loop.
I really know how to use FB40/41 for multi loop control as description above. And if anybody have any ideal, or suggestion, pls send me via [email protected]. And if anybody have any interesting link website, also send to me via above address.
Thank you in advances.
Nguyen Van Hong
Nguyen Van Hong
