K
We operating GE steam turbine generator and kept having thrust bearing drain active alarm. The inactive thrust bearing drain is exceeding the set alarm set point. please what will be the effect on the lube system?
R | Problem with thrust measurement - Bently 3300 XL | Instrumentation & Measurement | 0 | |
A | Maximum Axial Thrust Load in GE frame 9E | Power Generation | 0 | |
D | Setting Thrust Position on Bently 3300 | Power Generation | 1 | |
S | turbine thrust bearing wear | Power Generation | 0 | |
A | GE GT 9EA Inactive thrust bearing temperature high | Process Control | 4 |
by Seth Price
by Bob Odhiambo
