Hello to all,
I'm doing an analysis of a specific event that includes a trip of a small plant. The control system is PCS 7 v 9.0. I don't have much experience with this particular system even though I know, it is specifically designed for process control in industry and it has all the feature of a modern DCS system.
I am in one particularly interesting and not easy explainable situation, where I can see a time difference (about 10 sec or more) between the timestamps recorded in the message lists (event, alarms, etc...) when the trip actually occurred and the timestamps I can see in the analog trends diagrams.
It is about the electrical measurements (currents, power etc), so when trip occurred and the circuit breaker is open, all these values must instantly go to zero, which is exactly what trends show. This is shown in the attached file and I can see the time instant when trip happened.
On the other hand, when I look event list in there are recorded messages such as Circuit breaker feedback OFF at about 10 sec earlier. This is a huge time difference, especially because of electrical values.
How to explain this?
Did anyone have similar issue?
I know this could be possible if for example a vale is shut down and there is a process quantity such as temperature or pressure that needs some time to rise or drop, but in case of electrical quantities such as current, it should be in the same sec.
According to the data from the PCS7, it seems hat currents flow 10 sec longer after circuit breaker is tripped. There are many binary signals in the event list such as "protection activated" cca 10 sec before analog trends show values suddenly go to zero.
