R
The question is: How a flow control loop employing a VFD as the means of flow control should be represented using ISA symbology.
Should the controller be represented as a "SC" for speed control or "FC" for flow control?
The question gets more interesting when using a VFD to control dryness of a product at the outlet of a screw driven by a VFD. The motor load will provide an inferred signal of the dryness. Therfore current is the measured value. In this case should the controller be reffered to as a "IC"?
