R
i want to make a control circuit wirless since the control cable that is used to transmit all control signals from a moving Tripper , and gets frequently cut since it passes through a heavy moving machine ( Tripper ) and wounds and unwounds on a drum.
we have a moving Tripper which is used to transfer the raw material (iron ore and coke) either to the bunkers through the conveyor belts or to make a stack there itself since it is moving through the entire length of the 80m long connveyor belt for the power and control circuit the cables are repeatedly wound and unwound on two separate drums , since the control cable is not as strong as the power cable due to tension or stress it gets cut sometimes .
Is it possible to make its control circuit wireless like all the signals required for the interlocks and other necessary signals will come to a transmitter which can be mounted on the tripper itself and from there it can be transmitted to a control room to a reciever where all signals will be separated as per requirement.
i want to know in what way it can be done ? which equipments will be required for the same?
and what will be the approx cost of this ?
