P
Do InTouch 8.0.2 integrates with DASABTCP 100.102.39.5?
If yes then i have a problem, It is showing DACmnProtFail Error.
All item names are active but has error (RED square)and asking to check the PLC selected and block size defined.
PLC is correct ie SLC-500 and block size kept is 200.
Pls suggest any solution.
First suggest on the version compatibility
