H
I want to transfer chunk data (e.g. 64KByte) with Modbus (RTU). But I have not found corresponding function code. Although the function code 0x03 can read hold registers, but at most 254 bytes are transfered though 0x03 function code. Because there is only one byte count in 0x03 function response frame.
Function 03: Read holding registers
The Modbus answer message starts with the slave device address and the function code 03. The next byte is the number of data bytes that follow. This value is two times the number of registers returned.
http://www.lammertbies.nl/comm/info/modbus.html
What should I do? Any ideas is appreciated!
