Has some else tryed to get a working connection between a Wago controller and a XBT-N200 terminal?
All by means of a Modbus RTU communication were the Controller is the slave and terminal the master.
Have used Wago Lib "TerminalSlave_04.lib" as a base but they wil not talk to each other.
Both use the same communication settings but it seems that the Wago controller keeps on waiting but I don't have a clue what that should be.
Hope to find some boy who has found a way to get a working communication between a XBT-n series terminal ans a Wago controller using the 750-653 clamp.
Even Wago Support got stuck on this one.
Check the connections, our friends from Schneider have recently changed the cable pinout for the XBT N200.
