Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Unquestionably, there is progress. The average American now pays out
twice as much in taxes as he formerly got in wages.
-- H. L. Mencken
-- H. L. Mencken
www.control.com/rss/
I need to implement a system including a generator with 12V output at 15W. I prefer to use an AC generator and rectify the output to get 12VDC. I have two constrains; 1) speed of water that turn the shaft (1m/s), 2) size. I system should fit in a 20x15x15 cm box.
I have done lot of search but the problem is that I can’t find any small permanent magnet generator that can be used.
I appreciate your suggestions.
How about a small permanent magnet servo motor? If it doesn't drive the voltage with the speed you want you can use a small transformer (rated for max load) to boost the voltage. A servo will drive pretty high currents at low speed, but you may not have the open circuit voltage to do your 12V (I assume it's a battery you are driving, and therefore need 12V+ ).
KEJR
KEJR
Google is your friend yet again. Check out what the hobby windmill folks are using. Their task is very similar to yours and there are some pretty good solutions out there. I have a surplus treadmill motor that would probably do the deed but it is a brushed unit. It wouldn't be very difficult to fit slip rings if you must have an AC unit. An inside out unit with a PM rotor would be easier. You might check out steppers as well to see if there are units with a PM rotor. Alternators are outrageously simple, but small units aren't very common.
cww
cww
It seems like you need to run at low RPM so you will need a multi-pole alternator unless you gear up. Here's a couple of suggestions:
Alternator from motorcycle or scooter.
Front hub type from pushbike (do they still make those?).
You may need to rewind in order to get 12 V but the winding is usually quite simple.
A lot of the home-built power plants use "Fisher & Paykel" washing machine motors (28 pole) but they are larger than you require.
Roy
Roy
Related articles from Control
Engineering magazine- Liquid level sensor: Non-mechanical optical technology extends application possibilities
- Wireless manager for instrumentation and control devices
- Level sensor: Magnetostrictive device extends mounting options
- New podcast: One road to wireless instrumentation
- Tutorial: Instrumentation / DCS integration languages, part 1, EDDL
- Rockwell Automation introduces virtual design and production software utility
- FactoryTalk industry-specific applications launched
- Upgraded communication modules make PLC to PLC communications easier
- Torque: Hall-effect sensor, reaction torque sensor, torque data acquisition
Subject to its Terms of Use.
