I'm not visual basic programmer, but I need to solve problem that the former programmer had left behind.
Some background about my system:
The PC has VB program.
The VB (running over XP operation system) communicates through USB to RS232 and communicates with electronic board.
I found out the when the XP allocate port number more then (estimation) 16, the VB program have problem to communicate with the board. (The problem disappears when the XP allocate port number less then 16).
* Is VB can handle port number that have high number (like com 45 etc')? and how...
* Can I force the XP to automatic allocate port number less then specific value?
Doron
Doron
I assume you are talking about the COM port number assigned to the virtual COM port established by the USB-serial converter module.
No, you cannot force XP to use a lower COM port number if all the lower COM port numbers have been assigned to other drivers.
But here is how I was able to specify an arbitrary COM port number in a C++ program. Instead of COM45, for example, call it out as:
\\.\COM45
Or, if Visual Basic treats\as an escape character, you have to double them up:
\\\\.\\COM45
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
\\.\COM45
\\\\.\\COM45
Robert Scott
Answers to your questions:
1. VB6 comes with an ActiveX control named MSCOMM which will not recognize any comm port above COM16.
2. You cannot enforce XP to assign any particular port id to the virtual comm ports, if lower ids are already taken.
Observations:
It seems that you have too many virtual serial ports in your system. Please, check if you have installed multiple drivers of USB based serial ports. Remove the unnecessary drivers. This may solve your problem right now.
If you really need many serial ports in the computer (forty-six seems way too many), then use a serial IO card that sits on your motherboard, not on your USB port.
Comtrol has such cards:
http://www.comtrol.com
If you have the source code of your original VB6 program, then you can use MCScomm control (from MCS electronics). It has many desirable features over the default MSCOMM control. And it supports many serial ports. Their site is:
http://www.mcselec.com/index.php?option=com_docman&task=doc_det ails&gid=151&Itemid=54
The suggestion of using "\\.\COM46" as port name is not applicable to your VB6 program. Because usual VB6 programs use MSCOMM, that doesn't access serial ports as "files". MCScomm does that, however.
Yeasir Rahul
http://www.voltsmith.com
Observations:
Yeasir Rahul
Optimization hinders evolution.
Learn from those who do, and become the expert today. Training Levels 1, 2, and 3 are available. Register Now!
