I'm new to the PLC game and wanted to know if anyone has successfully programmed a Micrologix 1100 to interact with a Telemecanique motor starter that has a modbus module (LUCB12BL). An example file or steps showing how to configure the serial channel in RSLogix500 would be greatly appreciated.
I have the PLC and motor starter wired using the RS485 wiring schematic for modbus. Im using the 1763-NC01 cable to connect the 3 wires required for modbus to the PLC.
Also, im a bit confused as to the master/slave terminology. Is my PLC the master and the motor starter the slave? My application is simply to monitor the status of the motor starter and report any errors to an HMI connected to the PLC.
cheers
aditya(at)eascan.com
cheers
