from the Forum department...
Modbus master
Communications systems and equipment. topic
Posted by Arun on 14 December, 2009 - 3:54 am
I have to test my modbus slave stack which contains all the modbus functions. But I don't have the Master part ready with me. Can any one suggest me with a Modbus master software for testing my modbus slave code.
Posted by Frank O'Gorman on 14 December, 2009 - 7:32 am
You could try ModMaster from:
http://wingpath.co.uk/modbus/modmaster.php
Frank O'Gorman
Wingpath Software Development
Posted by Darrin Hansen on 14 December, 2009 - 8:45 am
Modscan32 from www.win-tech.com is one of the most popular.
Darrin
Posted by Mark on 14 December, 2009 - 10:13 am
I find the master at www.simplymodbus.ca works well and is easy to use. There's almost no learning curve.
Posted by Mark on 14 December, 2009 - 12:22 pm
For Windows applications, check out Automated Solutions website.
Modbus Master ActiveX Control implements a broad range of Modbus functions including some obscure ones, and has support for intentionally generating bad Modbus packets to test your slave device's error handling.
http://automatedsolutions.com/products/modbusrtu.asp
Ready-to-run example apps will have you communicating immediately.
-Mark
Posted by Arun on 15 December, 2009 - 9:49 am
Thank you everybody, for the suggestions given till now...
Posted by TK on 16 December, 2009 - 12:42 pm
Modbus Test Pro is easy to use (although I may be biased since I helped develop it) and supports the most commonly used functions. The download is fully functional shareware with only a minor nag screen if you don't want to pay for it.
https://www.rogue-engr.com/cportal/index.php?option=com_virtuemart& amp;Itemid=49&vmcchk=1&Itemid=49
Posted by Andrzej on 23 December, 2009 - 3:30 pm
Try free tools Modbus Tester and Modbus Scanner from www.modbus.pl.
Andrzej
Posted by John Caldwell on 29 December, 2009 - 9:12 pm
I have written a Modbus Tester for serial as well as one for Modbus TCP/IP. Contact John Caldwell at Schneider Electric in New Zealand if you want a copy. (john [dot] caldwell [at] nz [dot] schneider-electric [dot] com)
Posted by Gonzalo Jimenez on 12 January, 2010 - 7:31 pm
I used to use one call Modbus Poll (http://www.modbustools.com/), I guess they have a newer version now. Very easy to use.
Good luck,
Gonzalo Jimenez Yamasaki
http://www.linkedin.com/in/gonzalojimenezyamasaki
http://sites.google.com/site/gonzalojimenezyamasaki/
Posted by Wassim on 13 January, 2010 - 11:44 am
This OPC Sever can act as a master. Here is a link to it:
http://www.matrikonopc.com/opc-drivers/128/base-driver-details.aspx
Wassim Daoud
Global Solutions Architect
www.MatrikonOPC.com
Cat, n.:
Lapwarmer with built-in buzzer.
Advertise here
Advertisement
our advertisers
