G
My query is that when the generator is synchronized with the grid, just after closing the circuit breakers, it enters into a stage called as floating generator.
In this stage, the voltage difference across the circuit breaker is ZERO. Also the frequency and the phase difference is ZERO.
When there is no potential difference across the breaker, the current can not start flowing in any direction.
For the current to flow from generator towards grid, the generator voltage is needed to be higher than the grid voltage. How then the current starts flowing which in turn introduces the armature reaction.
Please throw light onto this.
