We have a STG of 25MW capacity running in parallel with state electricity board. Recently we are observing a very interesting phenomenon, where in turbine axial bearing temp (Non active side is running high). The temp goes higher when the load is raised to full load and even it trips on high axial bearing temp. If out of three uncontrolled extractions are stopped the temp drops and STG can run on full load. The axial shift goes negative with full load and all extractions in line. All other parameters of STG set is within permissible limits.I am unable to under stand how does the extractions folw is affecting rotor float to this extent. Can any one suggest any further checks to understand this problem. Many of us are thinking at is may be due to saulting of blades in LP side (The M/c is Single Cylinder), however the specific steam consumption and wheel chamber pressure are within prescribed limits.
Rangacharya,
Rangacharya,
