I am trying to change the Fluid type and other variables of a rosemount 3095. I have a HART modem to hook up to the P.C. I understand these changes can only be made using the Engineering Assistant software by Emerson. I have this software, downloaded from Emerson, and its stand alone type cannot be installed unless i purchase the asset management software. I don't understand why its called stand alone if it needs A.M.S. Anyone have any ideas for making these changes happen without using the E.A software? These variables are not accessible with normal HART 375 communicator!
http://www2.emersonprocess.com/siteadmincenter/PM Rosemount Documents/00809-0100-4716.pdf
The method to change the variables i need, can be found from page 3-37 of the pdf, for which the link is above.
