During a fault with VCMI/H2B I wanted to replace it with the new one, but the version of new one is H2C and this version doesn't exist in the upgrade menu of toolbox. how do can I find VCMI/H2C firmware or where?
The Rev "C" VCMI should come with a CD containing the required .bin and .tre files. Instructions should also come with the CD. (Newer eTCSS versions have the required firmware, but yours apparently is older and needs the upgrade CD.) If you're not comfortable doing these changes, a GE controls TA is highly recommended.
