We are connecting a 4-20 ma o/p (24vdc loop powered) from bently nevada 3300/55 vms card directly to yokogawa AI card AAI143 (4 wire transmitter jumper set) to display the vibration readings in DCS. Yokogawa is not accepting the input and gives an Open loop alarm in the loop. When feeding with a milliamps source to Yokogawa AI channel, we can see readings in the DCS. Can any one help to connect the signal to dcs? I think it requires some Isolator or barrier to be used. Pleas suggest.
