Z
I am using AB 1400 PLC which is connecting with load cell indicator on RS485 Mod-bus RTU. Indicator is T6.2000 Transcell.
Problem is no communication between T6 and AB. I have checked all PLC setting is ok. for checking of PLC setting and hardware. I used T6.2020 load cell indicator from other machine to this machine now communication is ok its mean plc setting and plc hardware is ok. Then i compare parameter and jumper of both T6.2000 and T6.2020. all is same. I have two nos. of T6.2000 both behavior is same and both are new. Can any one face problem like this.
regards,
__________________
Zahid Ali Khan.
Rox Tech Engineering.
Township Lahore,
Pakistan.
regards,
__________________
Zahid Ali Khan.
Township Lahore,
Pakistan.
