Hello experts;
I start to study the gas turbine components.
I have a confusion about axial compressor
If barometric pressure at the site is 14.5 PSIA and Inlet filter differential pressure is 3 inch of water column, then what is the inlet pressure of the axial compressor.
It is 11 stage axial compressor. The compressure discharge pressure is 118 PSIG.
I want to calculate the pressure ratio but how and where i measure the Inlet compressor pressure?
Thanking you i will remain
