I stroked the actuator to 50% to insert the metal block that relieves spring force, so that I could remove the actuator to replace the valve. New valve set at fully closed position, reinstalled actuator, removed block. Started valve calibration application, starts up with -2.5% setpoint, LVDT shows 0% actual position with 0.7 volts. When I enable manual function, desired setpoint goes to zero, but SRV moves to 1.7% actual position with LVDT voltage at 0.75 volts.
The SRV valve symbol on the HMI DLN screen also changes to red (shows open).
