I would check out common everyday switching power supplies. Many of them will accept that DC range as well as a wide range of AC.
IIRC the Rhino supplies are rated for this at Automation Direct, so I would think it fairly common. Since they have no input transformer in a switcher, it doesn't care how the input capacitors get charged.
In fact he may be able to go directly to a 24VDC charge controller.
I use a PowerMax PM3-100 PFC to convert from my hybrid car's 144VDC battery to charge two 12V batteries for the aftermarket audio system (car has no alternator, so I couldn't put in a bigger one). It is marketed as AC to DC, but I emailed their tech support and was assured I could just lop off the AC plug and wire it to 144VDC. Did that over a year ago and it's been working fine ever since.
> The AD supplies want a little higher range, but the point
> is that OTS supplies will handle that range.
Not sure what your point is about little higher range. The linked material gives an input of 103-127VAC, 90-160VDC.
The PowerMax SM3-50-24 (rated 50A, 24V nominal, 3-stage charger out) has an input range of 105-135VAC giving it a top end of ~190VDC... which is a bit higher than what you linked (I wouldn't worry about the 90V low end DC range as long as it had enough amperage for max DC out plus converter losses).
I will agree however, what you linked is geared more for commercial, industrial, military applications.
