I am seeking a solution to what I thought wouldn't be such a complicated problem. I need to run a conveyor belt 15-inches wide, that will run a folder and circular 13" disk through an imaging device that will take an image, top and bottom of the folder and disk @ Approx 20MP per 15x15" region scanned or better. It would be preferable to find a scan head or similar that can be placed in a small gap between belt conveyors. Is there such a device? Do they make a scan head that can be attached to a conveyor? The scan heads will need to accommodate a folder that is no more than 1/4" thick.
Thank you,
Caleb
Thank you,
Caleb
