L
I have 6 x 1.5kW AC induction motors which are being used as blowers in a galvanizing plant. Air flow is controlled by using dampers.
We are planning to remove dampers and install VFDs to control the speed the blower.
My question is, is installing VFDs a cost effective solution rather than replacing the AC motor with BLDC and its associated circuits?
If any if you can help me find the issues/cost effectiveness of the BLDC solution, that would be great.
Lakmal
Lakmal
