I know this is going to be PAINFULLY simple to some of you. However I haven't used a 4-20mA sensor in +10 years. I am a hobbyist who is looking to build a sensor system that I will use at work.
I have my controller figured out, which will read the 1-5V signal derived from the voltage drop across a 250 ohm resistor. What I can't remember is if I have to send a set current of 20mA to the sensor, or will it automatically output 20mA (or less) even if I send lets say 200mA....
Do I require a power supply for this sensor that supplies exactly 20mA? Are there power supply conditioners that will do this for me?
I truly appreciate any response.
Best regards,
Joe
Best regards,
Joe
