T
All remote seal applications in my plant was for level measurements. is it accurate to use this (with threaded option) to measure flow (of a solution that always cause blockages in the samples)? this flow is measured through DP measurement (Orifice). so my question is about response time in this measuring technique, as i'm willing to use a capillary oil-filled with length up-to 7 meters. what do you think guys?
