I,m trying to configure hand indication control (HIC) doing the following:
1- configure AI, MANUAL LOADER, AO in control studio named as 100-hic-401 and i use AO_FP AND AO_DT with this tag properties. when i go online and make simulation for my configuration it is good.
2- but my problem is in Delta V operator. i add valve dynamo in one picture for cooling water system. and when i press on this valve (on operator mode) the face plate of analog output opened with errors (dvsys.@modfb@.... does not exist, and many other errors ). when i skip these errors and try to increase output also i get error message.
how can i fix?
how can i fix?
