Using the parallel or independent PID equation with e=sp-pv for temperature control of a electrically heated furnace. Ki is 1/sec and Kd is secs. Dead time for process is about 2 minutes. Using Allen Bradley hardware (plc5/40e) and software and now have PID block with update at 1 second. The STI is not configured and the plc scan time is about 34 ms. Have question on the changing the update time for the PID block. If the time was changed from 1 second to 2 second would the output related to the integral part of the equation change given the slow changing temperature loop? Or if it was changed to 10 seconds would the integral related output change much? In the Allen Bradley PID equation I don't see the scan time so I am thinking would not change if scan time was to change and don't see this changing much the area under the error/time curve.
