K
Cooling water leakage at the turbine support leg, not at the welded joint, but along the vertical edge of the support. how can i repair this leak thru welding? what is the base material of this component?
| Thread starter | Similar threads | Forum | Replies | Date |
| M | Turbine Exhaust Frame Cooling Blower & Motor GE Frame 6B | Power Generation | 8 | |
| A | GE Frame 6 Cooling water pressure hunting | Power Generation | 10 | |
| S | Cooling Methods for Frame 6 Gas Turbine | Power Generation | 1 | |
| K | Frame 9E Cooling Water System | Power Generation | 8 | |
| J | Both Frame Cooling Fan required for frame VI GT? (Mark V) | General Automation Chat | 3 |
