Steam Turbine Condenser is equipped with online rubber ball cleaning system. The system currently is out of order due to lost rubber balls. The balls sent in is not equal to balls received after washing.
How much impact will it have on Steam turbine efficiency?
What can be the reason for lost balls in circuit?
What material for ball is used for condenser tubes cleaning?
