Tuesday, June 19, 2018
Simatic OPC Scout 2.3
Shortly,what I need: 1) Some manual/datasheet for Simatic OPC Scout 2.3 2) Some program example in C/C++/C# to create database from OPC (DB's in PLC)
I need the manual/datasheet for Simatic OPC Scout 2.3. I have a testing machine of pneumatic valves. It is controlled by Simatic S7-300 and communicate with LabVIEW 7.1 using OPC Scout 2.3. It is running on old Siemens PC with Windows 2000 (it has integrated Profibus for connect to PLC). I need to create some database from data in PLC. I am not good in C languages is there anyone who can help me with this? Is it possible or I have to for example generate the data in LabVIEW to .csv file and then use some C program to create database from it?
Thank you very much for any help.
There appears to be no manual for the Scout but the following may be helpful:
https://www.siemens-pro.ru/docs/simatic/s7-1200/39960679_S7-1200_OPC_SIMATIC-NET_e.pdf
https://cache.industry.siemens.com/dl/files/679/39960679/att_117996/v3/39960679_s7-1200_opc_simatic-net_tia-portal_e.pdf
https://cache.industry.siemens.com/dl/files/666/13542666/att_72780/v1/PH_PC-Stations_76.pdf
