P
I’m a Sri Lankan student following Bsc. in computing. I hope to develop intelligent building software as my final year project.
A brief description of my project:
I need to get values from sensors (Ex: temperature = 32C) with sensor ID (to identify the sensor) that installed in the building. These signals will be simulated by using a simulator because I’m doing a computing project and I’m not going to interface with the hardware. These values will then evaluate with the program that is to be build, according to the energy saving and user adaptability of the building. If the program decides whether any change necessary to the environment it will send action signal to an actuator which can change the environment. I’ll also simulate these actions.
Is this possible with modbus protocol?
Example Scenario:
It is detected that sunlight produces high light level. Then the system can open blinds to let the sunlight into the building in order to save energy.
Example Scenario:
