Hello All !!
Could someone, please help me out by explaing the role of FSRMIN & FSRMINN & FSRN?
In many threads regarding FSRMIN FSRMINN and FSRN, engineers have asked the queries as why the mentioned outputs are not working in their sites as they have understood the basics. While I am asking the basic working of the same. Any explanation will be grateful and helpful.
When I refer to the HELP block of FSRMINV2, what I understand is
> FSKMINN & FSKMIND constants comes in line to calculate FSRMINN when L83MIND i.e L94X / L14HS becomes TRUE w.r.t TNHCOR, which is clear.
> FSKMINU constants comes in line to calculate FSRMINN when L83MIND i.e L94X / L14HS becomes FALSE w.r.t TNHCOR.
Q1. What is FSKMINU (FSKMIN FSR corner (FSRSU). How does it contribute to FSRMINN and work?
Q2. Why there is only 2 array value, [1] & [3]?
Q3. Is value of [3] is taken from FSKMIND array values? If so why?
FSRMIN - Minimum Fuel Stroke reference
Q1. Why it is derived from FSRMINN?
Q2. Why this value is alone multiplied with CQTC( corrected air temp factor) ?
Q3. What & when it contribute ?
FSRN- Droop Speed Control FSR
Q1. What is FSRN (Droop speed control FSR) ? I know mathematically it is [(TNR-TNH) x FSKRN2)] +[FSKRN1 + TLC_CMP]
Q2. What is transient load Bias , TLC_CMP? What doe it do?
Q3. In one of the thread, I read that TNR increases when load is increased and reaches 104% (droop set -point) when machine is at Baseload. How and Why? Does it proportionally increase?
Q4. TNH tries to catch up its reference TNR. I know TNH is restricted by due to frequency that has to be maintained (50Hz/60Hz). As far as i understand a Load increase means increase in Rotor current > increase in magnetic field tries to stop the rotor and is in-turn fuel valve opens further to increase energy to maintain the speed. Then why does TNR increases and load increases while the speed has to be maintained at 100%, while the more energy is given by introducing more fuel ?
Q5. Why there is a DROOP set point and why it is required?
Q6. What is role of FSRN when the generator breaker opens?
Suds
Suds
