Hello everyone,
I’m working with a 4-leg inverter topology (artificial neutral) supplying unbalanced / asymmetric phase currents.
The objective is to stabilize the neutral point even under intentionally asymmetric phase currents.
System overview:
Observed problem:
Under unbalanced phase currents, the neutral point shows periodic oscillations at 150 Hz.
Despite extensive PI tuning:
1.The controller either reacts too slowly
2.Or becomes overly aggressive
3.Yet the 150 Hz oscillation persists
Adjusting gains improves performance only marginally. The behavior seems structurally limited, not just a tuning issue.
What was tried:
Oscillatory behavior persists under asymmetric load conditions.
Question:
Is this a fundamental limitation of PI control for stabilizing an artificial neutral in a 4-leg inverter with unbalanced phase currents?
Have you encountered similar behavior or used alternative control structures for this? Any insights would be appreciated.
System overview:
- 4-leg inverter with active neutral leg
- Neutral controlled via feedback (neutral current / voltage)
- Classical PI controller
- Digital control implementation
Observed problem:
What was tried:
- Different PI gains
- Integrator limiting
- Increased sampling rate
Question:
