Control eBook: The Guide To Source and Sink Controller Wiring with PNP and NPN Devices
This eBook will discuss both the control system modules (considering both PLC and distributed I/O) as well as the sensors and output devices that interface with the control systems.
eBook Overview
Installing and troubleshooting control systems involves a lot of wiring. Even though many modern control systems rely on wireless communication devices, there will always be electrical connections between I/O devices and controllers. In many facilities and industries, the documentation for the system has been lost or is difficult to interpret. Electrical system diagnosis is among the most challenging maintenance tasks, often left up to those with the most experience.
If you find yourself facing this common situation of electrical troubleshooting but have few resources at your disposal, it helps to understand how and why the devices are chosen and connected.
Your short summaries mix conventional and electron flow and are wrong.
A sourcing module has + connected to its common and supplies conventional current from the I/O terminals out to the field devices.
A sinking module has - connected to its common and receives conventional current from the field devices back to the I/O terminals.
To avoid confusion I find it best to stick exclusively to conventional current flow.
Reading this book will enhance my knowledge on the subject
