R
I have a problem with a wonderware application. I am running Intouch 7.0 on NT. I am running Control Microsystems OPC Server to communicate with 8 RTUs via VHF radio. My problem is that in the last few days the wonderware will not show "real time" information and my OPC server says it has a 100% fail rate on communication. However, I can still control the digital I/O at one of the RTUs with the supposed 100% failed through-put. I can only manipulate the Digital I/O. All analog values are either "0" or "full scale." After some time (different each time it happens)the system will return to perfect functioning order. I have rebooted the system and the radios/modems to no avail. Any help is appreciated........
