I need a wiring diagram to connect my notebooks com port to the a984-145 so that I can program it with proworx. Is it a straight through cable or do I need to do some pin swapping? Thanks!
The wiring is specific there are 3 crossovers and a loopback.
Search internet for modicon 984 145 programing cable. You also need to refer to operations manual there is specific protocal for first time acess you must use.
