Hi, I am on a project to install new feed preheaters on columns that use the base of another column as a heat source. Seems like bypass control is the way to go. Do I use only one control valve on the bypass line or do I use two control valves, one on the bypass and one going into the preheater working inverse of each other? Thanks.
