What is the problem of high vibration on Y side in input bearing side of single stage steam turbine? The probe and cable with SKF sys are ok after we test and swap them also.
If you have confirmed that the vibration monitoring equipment is working as they should, the next step is to consider that the high reading is true and that there is a actual vibration problems. Get the mechanical department to check it and let them know your equipment have been checked and why you believe this to be a actual vibration problem.
If you believe this is not a true vibration and something is wrong with your equipment you need to give us as much detail on your system as you can and also let us know what you have done so far to resolve the problem.
