Hi, how are you? Please your help, how can I fix this:
As you can see, the Live Data for Position Feedback Secondary Gas Control Valve #1 and Position Feedback Secondary Gas Control Valve #2 shows Infinity U, MOOG valves works with two LVDT's KAVLICO. This picture is about LVDT's tab in ToolboxST Mark ViE. Control loop is working good, in a test we wired LVDT's Secondary valve cables to Quaternary valve and information in Mark ViE is OK. MinVrms and MaxVrms were in zero (0), values in picture were set manually.
We tried to CALIBRATE Secondary valve again but it seems this procedure depends on feedback value, which is Infinity U.
Maybe does anyone here some tip to fix it!
