for my university project, i have to design a liquid leakage sensor. the sensor will be placed somewhere on the floor of a room and it must monitor the variation in liquid if spillage or leakage occurs
The problem now is that the output of the sensor must be analogue - it must monitor the height of the liquid up until 5mm. when the liquid level reaches 5mm, the alarm will trigger. The sensor also must be designed using the following specifications:
- height: 5mm
- width & length: 10mm
- must be able to detect conductive and non conductive liquid (eg: water, oil, petrol, sulphuric acid etc)
- not too expensive
- able to detect the liquid within 1m2 area around the sensor
i have been trying to use capacitance with the liquid as dielectric material but i'm not sure if it might work. if also thought about using potential dividers but it may become problematic when using liquids with low conductivity.
- height: 5mm
- not too expensive
