Hi Guys,
We have 4 Generators need to connect by synchronization together in one busbar and we have 4 Loads (Each load has one circuit breakers) , there are 2 deign need to fixed which one the typical, the first one is put all the generators in one side (like the left side) and the loads in the other side (at the right), the second design is put the first generator in the left then the first load (beside the 1st generator) then the second generator then the second load then the third generator then the third load then the fourth generator then the fourth load, i.e. ( distribute the loads between the generators), knowing that we don't have national grid, i.e. we have just one source consists of 4 generators and 4 loads.
