Hi All,
Need help to test this ATOS servo proportional direction control valve (EXPLOSION PROOF) . This one has 12 V DC coil and one position transducer, electronics are not inbuilt. On the position transducer (LVDT), are four spots for the supply voltage is +15V, -15 V, output signal and ground, whereas on coil side there are three spots for coil+, coil- and GND. Can someone help me to test this valve with the help of valve checker that I have without the hydraulic test bench? Thank you.
