N
Hi
I Hope someone out their can help me I have the following problem:
I have a 10 HP VFD Reliance SP500 Series 600V 3 Phase, 1740 RPM
I have line reactor connected on the line side (recommended by MFG)
Supply voltage is 570-585 VAC
Connected to a 10 HP motor/gearbox/pump
The problem is every 12 hours or so the VFD trips out on HU (high bus fault). I would like to know what causes this and how can I prevent it?
Thank you very much.
