E
A wheel with a diameter of 139.802mm is mounted on the shaft of a servo motor which has an encoder resolution of 8000 counts and a gear box of 12:1 (therefore, a resolution of 96000counts/rev).
This wheel is used to drive a belt (stretched at the other side with a free wheel of similar dimensions) at increments of 10.7mm at per step. Can anyone tell me the proper method of calculating the required counts to perform this step of 10.7mm? To me, at the moment, it does not seem possible...
regards,
eugene
regards,
eugene
