I have 3 phase power that has a high leg of 211 volts to ground. The other two legs are 120 volt to ground. Is it fine to run a three phase machine onthis voltage?
| Thread starter | Similar threads | Forum | Replies | Date |
| A | How long is the LVDT if my process (tank) is 2.5 meters of high? | Process Control | 2 | |
| G | High Leg Open Delta Calculation | Power Generation | 3 | |
| B | Re: High Leg on 3 Phase Power | General Automation Chat | 0 | |
| M | High Leg on 3 Phase Power | General Automation Chat | 2 | |
| J | grounding high leg delta systems | General Automation Chat | 0 |
