I need help w/ timer delay
Need to call sum fx tgether in a loop
B4 execute next fx, there is a delay of 200ms
I tried this
'Walk
Private Sub Walk_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Walk.Click
Dim a As String
Dim b As Integer
Dim c As String
Dim d As String
a = &HFF
b = &H5F
c = &H11
Call RLeg_Up()
Timer2.Start()
d = (SendWalk(0) Xor SendWalk(1) Xor SendWalk(2) Xor SendWalk(3) Xor SendWalk(4) Xor SendWalk(5) Xor SendWalk(6) Xor SendWalk(7) Xor SendWalk(8) Xor SendWalk(9) Xor SendWalk(10) Xor SendWalk(11) Xor SendWalk(12) Xor SendWalk(13) Xor SendWalk(14) Xor SendWalk(15) Xor SendWalk(16)) And &H7F
Dim all As Byte() = {a, b, c, SendWalk(0), SendWalk(1), SendWalk(2), SendWalk(3), SendWalk(4), SendWalk(5), SendWalk(6), SendWalk(7), SendWalk(8), SendWalk(9), SendWalk(10), SendWalk(11), SendWalk(12), SendWalk(13), SendWalk(14), SendWalk(15), SendWalk(16), d}
SerialPort1.Open()
SerialPort1.Write(all, 0, 21)
SerialPort1.Close()
End Sub
Private Sub Timer2_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer2.Tick
Timer2.Stop()
If Timer2.Interval = 3000 Then
Call RLeg_Down()
End If
End Sub
To call RLeg_Up first, b4 RLeg_Down
RLeg_Up is called n then nothing happens
Help??
I tried this
'Walk
Dim a As String
Dim b As Integer
Dim c As String
Dim d As String
a = &HFF
b = &H5F
c = &H11
Call RLeg_Up()
Timer2.Start()
SerialPort1.Open()
SerialPort1.Close()
End Sub
Timer2.Stop()
Call RLeg_Down()
End If
End Sub
Help??
